| Posted by Dale's Plumbing Service Inc LMp on March 13, 19100 at 06:03:16: | |
| In response to Re: Toilet Flushing Very Slow | |
: I wondering if there is any thing you could suggest. The toilet in my upstairs bathroom when flushed : the water doesn't swirl and the contents go down. There seems to be enough water in the tank. This problem usually accurs when the port hole under the rim of the bowl plug up with calcium from hard water. Also it can build up in the trap of the toilet and closet bend. Or you may have something in the toilet. Use a hand held mirror to look under the rim of the bowl. Use a coat hanger to unplug holes and. You may need to treat your bowl with muratic acid. Read directions and where safty glasses. Do not let the fumes escape. Call a plumber if you have doubts. Dale's Plumbing Service Inc LMp |
| There are none. |
