| Posted by Dale's Plumbing Service Inc LMp on March 13, 19100 at 05:56:52: | |
| In response to Re: drain odor in bathroom sink | |
: My downstairs bathroom has a terrible odor emanating from sink drain. The j trap is clean and : has water in the trap. When I run the water with the drain closed, there is no odor. When I open : the drain and the water flows through, the odor is bad. Any ideas? The over flow in the lav needs a good cleaning.Use bleach to clean. Pout it in to the over flow tube in the lav.There are other products you can purchace from your local hardware also. Dale's Plumbing Service Inc LMp |
| There are none. |
