: I need to drill thru Two joist to get a 3" pvc pipe thru a 2* 12 (11 1/4), what is the recomended hole threw the joist to meet code?? If I am within 5'of the stack , I think I don't need a vent is that correct?? Thank you John, The best thing for you to do is ask your local building inspector. If i were doing it I would just do it as i have had no problems in the past. Stay in the center as much as you can and use a 3-1/2" hole saw.But again check with the building code official in your area. Dale's Plumbing Service Inc LMp
