| Posted by hj on March 11, 19100 at 16:37:29: | |
| In response to Re: Shower cold water handle keeps turning | |
I assume you have the one with the stop built into the handle. If so, then you need a new handle. Some units have the stop on a sleeve that goes around the stem. In that case you need a new sleeve. They are colored red and blue depending on whether you need hot or cold. : Hello, The problem I have is with the Moen shower cold water handle. No leaks or anything, but when we go to shut the water tap (handle) off, it doesn't stop, butkeeps turning and turning. I am not sure what is causing this , but is there is a part I have to buy, or repalce the whole handle? All responses would be greratly appreciated.
| There are none. |
