Re: tub drain leak
Posted by Dale's Plumbing Service Inc LMP on March 07, 19100 at 04:42:49:
In response to Re: tub drain leak
: I have a second floor bathtub that is used very infrequently. I believe there is a very small leak at the drain.
: The symptoms are that paint seems to peal off right below the drain on the first floor ceiling. There is
: not enough water to discolor the ceiling. I am guessing that the drain isn't seated correctly or the putty
: is cracked. Is it possible to remove the drain from above and reseat it without cutting through the ceiling?
: Is there anything else I need to know?
I have a second floor bathtub that is used very infrequently. If this tub were used a lot then the leak would be worse, right?. I would just cut the ceiling out find and repair the leak. Just my opinion. Dale's Plumbing Service Inc LMP
Replies to this post
There are none.
