| Posted by Richk on March 06, 19100 at 18:11:44: | |
I have a second floor bathtub that is used very infrequently. I believe there is a very small leak at the drain. The symptoms are that paint seems to peal off right below the drain on the first floor ceiling. There is not enough water to discolor the ceiling. I am guessing that the drain isn't seated correctly or the putty is cracked. Is it possible to remove the drain from above and reseat it without cutting through the ceiling? Is there anything else I need to know? |
