| Posted by Dale's Plumbing Service LMP on March 04, 19100 at 11:09:33: | |
| In response to Re: toliet | |
: replaced the hardware inside the tank it was running : fine then it started running at the top all day long can't figure it out . There may be some crud under the washer that will not allow the fill valve to shut off. Or if you have a float rod that is bent it turned up and now it won't let won't let the water shut off. Dale's Plumbing Service LMP |
| There are none. |
