Re: venting around new window
Posted by Dale's Plumbing Service LMP on March 04, 19100 at 02:39:13:
In response to Re: venting around new window
: I'm installing a new 6' wide itchen window. The sink will be centered on the window. The vent will have to be offset about 3 1/2' from the trap. Can I simply run the drainpipe from the p trap,into the wall, turn left and connect to a drain/vent that I install 40"-48" away? Thanks. Louie Louie, Yes you can. It should work fine. Put a clean out in this line for future use. Never Know, you may need it some day.Dale's Plumbing Service LMP
Replies to this post
There are none. |
