| Posted by Dale's Plumbing Service LMP on March 03, 19100 at 18:25:37: | |
| In response to Re: Thanks Dale. What about toilet too close to wider tub? | |
: Dale, : Thank you for you input. I did go to the plumbing supply store before I got your advice. They told me to saw : Mark Mark, If you can tie onto the cast iron go for it. You didn't give that option in your last post. The center being closer than 15" from a finished wall is not good. If you can live with it its your call. If this is being inspected you need to re-rough in the waste for the toilet. I you can put a street 22 on the cast iron (being horzontal) you can move the waste for the toilet as long as you have room off the opposet wall.Dale's Plumbing Service LMP
| There are none. |
