Re: No water from well pump HELP!
Posted by Dale's Plumbing Service LMP on March 03, 19100 at 16:37:49:
In response to Re: No water from well pump HELP!
: Hi. After doing a load of laundry today, I turned one of the upstairs faucets on and I now have no water. I have a well with a Red Jacket well pump. The xtrol tank is empty but the pressure gauge reads the usual 40lbs. What can I do to find out the cause of the lack of water? Is there such a thing as the pump losing its prime? I tried turning the well pump fuse of and back on, but no luck. Before I call a plumber, I wanted to troubleshoot everything that I could. Thanks. Kate, check the nipple that the pressure switch is screwed into. I may be clogged solid with rust.That is the first step. Hope it works. Dale's Plumbing Service LMP
Replies to this post
There are none. |
