Re: lead to pvc toilet
Posted by Dale's Plumbing Service LMP on March 03, 19100 at 16:35:16:
In response to Re: lead to pvc toilet
: I am remodeling the bathroom this topic concerns my toilet, and have found soft 4" lead that feeds into cast iron. I cut the lead so it is even \
: and would like to extend 4" pvc pipe from the lead to sufficient length to put a toilet flange on the pvc. My
: question is how do you conect the pvc and the lead. The lead is so soft that it does not seem feasible
: to put a clamp around them. Any suggestions would be greatly appreciated. Thank you in advance.
: Mark
Mark, Go to a plumbing supply and ask for a 4"S&D x 4pvc adapter. Then use a round tool (an 1/1/4 dowel works fine). take a hammer and put the dowel into the lead and tap it easily all the way around it so the S&D part fits INSIDE of the lead. Then use a no hub clamp to tighten. Hope this helps. Dale's Plumbing Service LMP
Replies to this post
There are none.
