| Posted by Joe Gabbard on March 02, 19100 at 13:37:40: | |
| In response to Re: adding second 3-4" stack | |
hey thanks terry! great resource for us "wreck-it-yourselfers" joe : : : : My question is: : Yes, Terry : : And if so, should I use a 1/4" per foot, 1/8" per foot, or GREATER slope : 1/4" per foot or more is UPC code. Terry : : I have 2 feet of vertical space (across the lateral 17 feet) to work with. : Sounds like plenty. You are only dropping 4-1/4" in that distance. Terry : : Did I mention I have to cut an iron stack in a 3 foot high crawl space :) : The cast iron stack can be cut with a saw blade, a sawzal works fine, or a cast iron cutter which you can rent. Terry
| There are none. |
