| Posted by Terry Love on March 02, 19100 at 12:04:40: | |
| In response to Re: adding second 3-4" stack | |
![]() : : My question is: Yes, Terry : And if so, should I use a 1/4" per foot, 1/8" per foot, or GREATER slope 1/4" per foot or more is UPC code. Terry : I have 2 feet of vertical space (across the lateral 17 feet) to work with. Sounds like plenty. You are only dropping 4-1/4" in that distance. Terry : Did I mention I have to cut an iron stack in a 3 foot high crawl space :) The cast iron stack can be cut with a saw blade, a sawzal works fine, or a cast iron cutter which you can rent. Terry
