Re: Basement toliet flange
Posted by hj on March 02, 19100 at 08:21:21:
In response to Re: Basement toliet flange
You don't connect a plastic flange to cast iron pipe. You either get a clamp-on cast-iron flange or use lead and oakum with a conventional cast iron flange.
: I am installing a toliet in my basement. There is already a rough in (cast iron) for a toliet that is
: at or a little below the cement floor level. How do I connect a plastic toliet flange to the cast iron pipe?
: They is about a 1/2" space around the entire outside edge of the cast iron pipe. They put sytrofoam
: around the cast iron before they poured the floor.
: Thank you for your help.
Replies to this post
There are none.
