Re: Toilet spacing between wall/shower
Posted by Dale's Plumbing Service LMP on February 27, 19100 at 18:59:57:
In response to Re: Toilet spacing between wall/shower
: : John, 15" is required from finished wall on both sides. : His question was how much space from the neo angle to the toilet and the answer is that it depends on where you live. In most codes for residential that is 15" from the center of the toilet to the side of the shower. Form commercial it is usually 16" but not in all areas of the country. : Come on Dale, answer his question in total or don't bother. : Dick : 408.5 Setting. Fixtures Shall Be Set Level And In Proper Alignment With Reference To Adjacent Walls. No Water Closet Or Bidet Shall Be Set Closer Than Fifteen (15) Inches From Its Center To Any Side Wall Or Obstruction Nor Closer Than Thirty (30) Inches Center To Center To Any Similar Fixture.The Clear Space In Front Of Any Water Closet Or Bidet Shall Not Be Less Than Twenty-Four (24) Inches. No Urinal Shall Be Set Closer Than Twelve(12) Inches From Its Center To Any Side Wall Or Partition Nor Closer Than Twenty-Four (24) Inches Center To Center.
