| Posted by Dale's Plumbing Service Inc LMP on February 24, 19100 at 19:09:54: | |
| In response to Re: Kohler Rialto K3402 Flush Valve | |
: Water runs past the flush ball through the flush valve. : I replaced the flush ball several times, each time with a different brand of flush ball, to include the Korky 1.6 by Lavelle. However, the water persists to trickle into the toliet bowl. : Question: Can I repair the flush valve or do I need to replace the flush valve and flush ball as one assemble? The assembly will cost me ~$25.00! : Please help. Thanks, Ed Comparon, San Antonio, TX Ed, Are there ears that you install the corkey to? If so it says to cut off the rest of the corky. There are lines on the corky that show you where to cut. Hope this Helps. Dale's Plumbing Service Inc LMP |
| There are none. |
