Re: calcification affecting toilet - Correction
Posted by Dale's Plumbing Service Inc LMP on February 24, 19100 at 18:52:59:
In response to Re: calcification affecting toilet - Correction
: First line should read "at least partially stopped up." Word "partially" was erroneously left out of the original posting. Marg, I use a mild muratic acid. Pour into the overflow tube in the tank. Cover the tank immediately!! Use a coat hanger to clean out the port holes under the rim of the bowl. Use a small mirror and look and see if they are plugged. When useing the acid do not let the fumes escape. Cover the bowl with a towel while the acid is soaking. Where saftey glasses and rubber gloves. Read instructions!!!Dale's Plumbing Service Inc LMP
Replies to this post
There are none. |
