Re: Water stains around shower stall
Posted by Dale's Plumbing Service Inc LMP on February 24, 19100 at 05:47:12:
In response to Re: Water stains around shower stall
: I have an upstairs master bathroom with a shower stall. The house is 5 years old and the tiles are begining to "pop". Under the tiles ther is mold and water. What is the most like cause for this? Do I have to replace all the tiles in the bathroom and shower to repair? Brian, The probable cause to your tile problem is ...A bad installation. To correct this problem you should tear out all the tile and sheetrock and go back with wonder board (a concrete type board)> It can be cut with a utility knife. Then retile. You probably can save the tile. Soak in water to get the glue off. Hope this helps. Dale's Plumbing Service Inc LMP
Replies to this post
There are none. |
