| Posted by Daniel Sandoval on February 22, 19100 at 15:20:03: | |
Folks: I am installing a Central Vac system in mostly new work, adn I have to run 2" PVC all over the place. It will be a major pain-in-the-@#$%! to do this unless I can bore 2-1/2" holes through several 2x8 floor joists. (Solid, not wood I-beams). This is being done in new, or exposed old, work. The general carpentry book I have warns that 2" dia. is the max in a 2x8, and that applies to a bore right in the middle, within the first 1/3 of the span. Suppose I were to make a couple of scabs out of 2x6's (or even 2x8's) and surround the openings with these? Any other suggestions would be most welcome! Thank you. -DS |
| There are none. |
