| Posted by Dick on February 22, 19100 at 09:38:14: | |
| In response to Re: Can I install a gas line for the stove | |
: I am moving into a home that had an electric range and I have a gas range, is it feasible to run a gas line myself or should I have an expert do this ? : The new line would be going into an addition with a crawl space and the existing gas supply for the water tank is about 10 feet away. Sure you can. Just use some common sense and don't forget that you are working with gas. Ventilate, ventilate ventilate.... and then use a fan to ventilate some more! |
| There are none. |
