| Posted by dick on February 21, 19100 at 09:43:09: | |
| In response to Re: Hate low flow shower head | |
: Recently purchased new shower massage head and the pressure is so low that I can barely get the soap out of my hair. Is it possible to purchase a non-low flow shower head or to adjust the one I have. : Thanks. almost all manufacturer's realize that low flow showers and faucets are inadequate to satisfy some ( a lot?, a majority?, almost all?) customers. So they make the flow limiter very easy to remove or disable. Remove the shower head from the arm and look for a disk with a small hole in it. drill out this hole or remove the disk. While you have the shower head off, turn the shower on to make sure the shower head was your only problem. After you replace the shower head, call the local Gendarmes and turn yourself in for criminal activities.
| There are none. |
