: : I recently bought a 400,000 BTU Pool heater. I'm planning to run a 1" black pipe from the meter to crawl space then to the outside again(doing a shorcut). Do I need to bury lenght of the pipe in crawl space? What is the minimum depth should I bury the pipe thats outside the house. Is one inch pipe sufficient enough. Heater requires 1000 btu/hr WC 7"min : : maximum 14 WC.: : Any tips will be appreciated. : : Please help. : Hope this tip helps; Dale's Plumbing Service LMP : 1210.0 Material For Gas Piping : 1210.1 All Pipe Used For The Installation, Extension, Alteration, Or Repair Of : Any Gas Piping Shall Be Standard Weight Wrought Iron Or Steel (Galvanized : Or Black) Or Yellow Brass (Containing Not More Than Seventy-Five (75) Percent : Copper). Approved Pe Pipe May Be Used In Exterior Buried Piping Systems. : 1210.2 All Such Pipe Shall Be Either New, Or Shall Previously Have Been : Used For No Other Purpose Than Conveying Gas; It Shall Be In Good Condition : And Free From Internal Obstructions. Burred Ends Shall Be Reamed To The Full : Bore Of The Pipe. : 1210.3 All Fittings Used In Connection With The Above Piping Shall Be Of : Malleable Iron, Yellow Brass (Containing Not More Than Seventy-Five (75) : Percent Copper), Or Approved Plastic Fittings. : 1210.4 All Valves And Appurtenances Used In Connection With The : Above Piping Shall Be Of A Type Designed And Approved For Use With Fuel : Gas. : 1210.5 Valves Up To And Including Two (2) Inches Shall Be Brass : Or Other Approved Material. : 1211.0 Installation Of Gas Piping : 1211.1 All Joints In The Piping System, Unless Welded, Shall Be Screwed : Joints, Having Approved Standard Threads. Such Screwed Joints Shall Be Made : Up With Approved Pipe Joint Material, Insoluble In The Presence Of Fuel Gas : And Applied To The Male Threads Only. : 1211.2 All Welded Joints In The Piping System Shall Be Welded By A : Certified Pipeline Welder As Defined In Chapter 2 (See Welder, Pipe). : 1211.3 No Gas Piping Shall Be Installed In Or On The Ground Under Any : Building Or Structure And All Exposed Gas Piping Shall Be Kept At : Least Six (6)Inches Above Grade Or Structure. The Term'Building Or : Structure"Shall Include Structures Such As Porches And Steps, Whether : Covered Or Uncovered, Breezeways, Roofed Porte-Cocheres, Roofed Patios, : Carports,Covered Walks, Covered Driveways, And Similar Structures Or : Appurtenances. : Concealed Unprotected Gas Piping May Be Installed Above Grade In : Approved Recesses Or Channels. Exception: When Necessary Due To : Structural Conditions, Approved Type Gas Piping May Be Installed In : Other Locations, When Permission Has First Been Obtained From The : Administrative Authority. : 1211.4 Where Water Vapor Is Present In The Fuel Gas Served, Accessible : Drip Pipes Shall Be Provided At Points Where Condensation Will Tend To : Collect. : 1211.5 Ferrous Gas Piping Installed Underground In Exterior : Locations Shall Be Protected From Corrosion By Approved Coatings Or Wrapping : Materials Or By Any Other Approved Manner. All Horizontal Metallic : Piping Shall Have At Least Twelve (12) Inches Of Earth Cover Or Other : Equivalent Protection. : Plastic Gas Piping Shall Have At Least Eighteen (18) Inches Of Earth : Cover Or Other Equivalent Protection. Risers, Including : Prefabricated Risers Inserted With Plastic Pipe, Shall Be Metallic And : Shall Be Wrapped Or Coated To A Point At Least Six (6) Inches Above : Grade Or Protected In An Approved Manner. When A Riser Connects : Underground To Plastic Pipe, The Underground Horizontal Metallic Portion : Of The Riser Shall Extend At Least Thirty (30) Inches) Before Connecting : To The Plastic Pipe By Means Of An Approved Transition Fitting Or Adapter. : Exception: Listed One-Piece Ninety (90) Degree Transition Fittings Or : Risers May Have Less Than Thirty (30) Inches (0.8 In) Of Horizontal : Metallic Piping. : 1211.7 All Gas Pipe Protective Coatings Shall Be Approved Types, : Machine Applied, And Conform To Recognized Standards (Table 14-1). Field : Wrapping Shall Provide Equivalent Protection And Is Restricted To Those : Fittings And Short Sections Where The Factory Wrap Has Been Damaged Or : Necessarily Stripped For Threading Or Welding. Field Wrapping Shall : Conform To The Requirements Of Iapmo Installation Standard-I$-13. : Zinc Coatings (Galvanizing) Shall Not Be Deemed Adequate Protection : For Gas Piping Below Ground. Ferrous Metals In Exposed Exterior : Locations Shall Be Protected From Corrosion In A Manner Satisfactory To : The Administrative Authority. Inspection And Repair Shall Conform To : Iapmo Installation Standard Listed In Table 14-1. : 1211.8 All Gas Piping Shall Be Adequately Supported By Metal Straps Or : Hooks At Intervals Not To Exceed Those Shown In Table 12-2. Gas Piping : Installed Below Grade Shall Be Effectively Supported At All Points On : Undisturbed Or Well Compacted Soil Or Sand. : 1211.9 Gas Piping Supplying More Than One (1) Building On Any One (1) : Premises Shall Be Equipped With Separate Shutoff Valves To Each Building, So : Arranged That The Gas Supply Can Be Turned On Or Off To Any Individual Or : Separate Building. Such Shutoff Valve Shall Be Located Outside The : Building Supplies And Shall Be Readily Accessible At All Times. Buildings : Accessory To Single Family Residences Are Exempt From The Requirements : Of This Subsection. : 1211.10 Where Unions Are Necessary,Right And Left Nipples And : Couplings Shall Be Used. Ground-Joint Unions May Be Used At Exposed Fixture, : Appliance, Or Equipment Connections And In Exposed Exterior Locations : Immediately On The Discharge Side Of A Building Shutoff Valve. Heavy Duty : Flanged Type Unions May Be Used In Special Cases, When First Approved By : The Administrative Authority. Bushings Shall Not Be Used In Concealed : Locations. : 1211.11 When Air, Oxygen, Or Other Special Supplementary Gas Under : Pressure Is Introduced With The Regularly Supplied Gas, Either Directly Into : The Gas Piping System Or At Burners, A Device Approved By The : Administrative Authority And The Serving Gas Supplier Shall Be Installed To : Prevent Backflow Of Such Special Gas Into The Gas Piping System Or Serving : Gas Supplier'S Meter. This Device Shall Be Located Between The Source Of The : Special Gas And The Serving Gas Supplier'S Meter And Shall Be On The Gas Line : Leading To The Appliance Using The Special Gas. This Device May Be Either A : Spring Loaded Or Diaphragm Type Check Valve And Shall Be Capable Of : 126 : Fuel Piping 1211.12 - 1212.0 : Withstanding Any Pressure Which May Be Imposed On It. : 1211.12 When Liquefied Petroleum Or Other Standby Gas Is : Interconnected With The Regular Gas Piping System, An Approved : Three-Way Two-Port Valve Or Other Adequate Safeguard Acceptable : To The Administrative Authority And The Serving Gas Supplier Shall : Be Installed To Prevent Backflow Into Either Supply System. : 1211.13 Valves Used In Connection With Gas Piping Shall Be Approved : Types And Shall Be Accessible. : 1211.14 All Gas Outlets Located In A Barbecue Or Fireplace Shall Be : Controlled By An Approved Operating Valve Located In The Same Room And : Outside The Hearth, But Not More Than Four (4) Feet (1.2 M) From Such Outlets. : When Piping On The Discharge Side Of Any Such Control Valve Is Standard : Weight Brass Or Galvanized Steel, Such Piping May Be Embedded In Or : Surrounded By Not Less Than Two (2) Inches Of Concrete Or Masonry. : 1211.15 An Accessible Shutoff Valve Of A Type Set Forth In Section : 1211.13,Shall Be Installed In The Fuel Supply Piping Outside Of Each : Appliance And Ahead Of The Union Connection Thereto, And In Addition To : Any Valve On The Appliance. Shutoff Valves Shall Be Within Three (3) Feet : Of The Appliance. Shutoff Valves May Be Located Immediately Adjacent : To And Inside Or Under An Appliance When Placed In An Accessible And : Protected Location And When Such Appliance May Be Removed Without Removal : Of The Valve. Shutoff Valves May Be Accessibly Located Inside Wall : Heaters And Wall Furnaces Listed For Recessed Installation Where Necessary : Maintenance Can Be Performed Without Removal Of The Shutoff Valve. : 1211.16 An Electrically Continuous Insulated Number 18 Copper : Tracer Wire Or Other Approved Materials Shall Be Installed With And : Attached To Underground Non-Metallic Gas Piping And Shall Terminate Above : Grade At Each End. : 1211.17 Changes In Direction Of Gas Piping Shall Be Made By : Appropriate Use Of Fittings, Except Pe Gas Pipe And Tubing May Be : Bent To A Radius Of Not Less Than Twenty (20) Times The Nominal : Pipe Or Tubing Diameter. : 1212.0 Appliance Connectors : Appliance Connections Shall, At No Time, Have A Diameter Less Than : That Of The Inlet Connection To The Appliance As Provided By The : Manufacturer And Each Appliance Shall Be Rigidly Connected To The Gas : Piping With Materials As Provided In Section 1210,0. : Exception: A Gas Appliance May Be Connected With An Approved Listed : Metal Appliance Connector Under The Following Conditions: : (1)
