Re: Problem with sand in whirpool tub
Posted by Dale's Plumbing Service LMP on February 19, 19100 at 15:42:42:
In response to Re: Problem with sand in whirpool tub
: Everytime we use the jets in our whirlpool tub, it appears that sand is coming out of them. When we drain the tub, there is sand left in the bottom. Any ideas why? Thanks. Renee Carter, If you are on a well you are sucking sand off the bottom of the well. If you are on city water check for a leak under ground. If this is new construction the sandd may have gotten in the water line during installation. I need more information so i can give you a better answer. Hope this helps. Dale's Plumbing Service LMP
Replies to this post
There are none. |
