Re: Water heater safety in Garage Conversions
Posted by hj on February 16, 19100 at 00:58:06:
In response to Re: Water heater safety in Garage Conversions
The water heater room/space cannot be connected to the sleeping area in any way. The only exception is if you use a sealed/direct vent heater which extends both combustion air and flues to the outside of the building. You cannot field modify the water heater, it must be a manufactured unit. About $3,000.00, and 50 gallons is the largest size made.
: I am converting a garage into a sleeping quarters. The heater is now framed in with an access door to the room . heater is about 7 feet from the outside wall. Should I cut vent holes into the door allowing room air the enter the heater compartment or vent to the outside by putting vent pipes through the outside wall and into the heater compartment visa ducting. Are either of these method safe and acceptable?
Replies to this post
