| Posted by dick on February 15, 19100 at 09:53:57: | |
| In response to Re: replacement toilets, reliability, and water pressure | |
I'm curious, what about your old toilets is not performing?? I have 3 30 year old Kohler toilets and have replaced the fill valve in all of them with an American Standard Smart valve, and replaced the flush valve and overflow pipe in one of them. Everything else is porcelin, and should last another 100 years. New 1.6 GPF toilets rely on a more complex mechanism to get sufficient water velocity and suction, some have smaller and more convoluted drain passages. I don't want to sound too negative, the great majority of the time the new toilets will work almost as well as the old ones. and don't cause I think you are trading in a used Lincoln for a new Escort just because its new and shiney. After the shine wears off, you'll wish you had the Lincoln back. : I am faced with replacing 3 35 year old Kohler toilets that are no longer performing well. I am considering the TOTO Ultra Max and the Gerber Ultra Flush based on your recommendations. For the Gerber, I am wondering how to test my water pressure, and whether these toilets are reliable. How do the Gerber's fare in terms of repair costs? Can the flushmate mechanism be repaired by the user or is a plumber required? (The TOTO salesman intimated that the flushmate system required more repairs).
