Re: cultured marble to replace a shower insert
Posted by Dale's Plumbing Service LMP on February 13, 19100 at 08:01:45:
In response to Re: cultured marble to replace a shower insert
: I want to replace a 36" x 48" fiberglass shower insert with a cultured marble base and walls. The plan is to use greenboard behind the marble wall panels. My question is: Does the greenboard need to go all the way to the floor, or can it stop at the top of the base? My problem will be that if it must go to the floor I will not have room for the 48" base and would need to move one of the walls---a bit more than I bargained for. Thanks! Ray, A much better board is wonder board. It is a cement board and can be cut with a sheet rock knife. If you use the other sheet rock leave it 1/4" above the base.The base goes in first the sheet rock over the top. 1/4" clearance. Dale's Plumbing Service LMP
Replies to this post
There are none. |
