Leaky Tub Faucet
Posted by Mark Brennan on February 08, 19100 at 13:06:55:
I have tried everything. Replaced the main stem and components, replaced the seat but still leaks Hot water only, cold I fixed OK. Also When the hot water is first turned on the water runs fine until it gets hot then it almost seems to shut off. I have to open the valve somwhat more in order for the flow to continue. Never had this problem until I started to rebuild the faucet no I can't stop it from leaking. Any advise you can provide would greatly be appreciated.
Replies to this post
