Clogged Shower/Sink drain
Posted by Kevin on February 07, 19100 at 11:15:46:
I have a shower drain and sink drain that eventually feed into the same drain that goes into the ground. It is clogged pretty bad. Water will still drain but very slow. I have used a small snake. I have used the Liquid Plumber foam cleaner. Neither has worked. A friend suggested using Liquid Heat. He says that he has used it in the past, and it worked great with no harm to the pipes. What are some your opinions on using this stuff? Thanks.
