Re: leaky faucet
Posted by hj on February 07, 19100 at 01:40:05:
In response to Re: leaky faucet
If it is a bad seal, then it can be replaced, if the faucet is defective, then the "two year" period is critical, since the faucet should have been guaranteed for two years, so the exact age is important.
: I have a Kohler "Coralais" single lever kitchen faucet. It leaks between the lever and the rest of the faucet. A steady stream of water comes out of the back end of the faucet whenever the water is turned on. It does not matter whether it is the hot or cold side.
: What can I do? The faucet is two years old.
: Any help would be appreciated, since I have only dealt with Delta single levers before.
: Thanks
Replies to this post
There are none.
