| Posted by Dale's Plumbing Service LMP on February 06, 19100 at 23:06:32: | |
| In response to Re: leaky faucet | |
: I have a Kohler "Coralais" single lever kitchen faucet. It leaks between the lever and the rest of the faucet. A steady stream of water comes out of the back end of the faucet whenever the water is turned on. It does not matter whether it is the hot or cold side. : What can I do? The faucet is two years old. : Any help would be appreciated, since I have only dealt with Delta single levers before. : Thanks I have not repaired this particular faucet but the good thing is you know the brand name and model. Go to your local plumber and purchace a repair kit for this faucet. It sounds like the o-rings are bad. Dale's Plumbing Service LMP |
| There are none. |
