| Posted by MARSTON PLUMBING/LAS VEGAS on February 05, 19100 at 23:50:28: | |
| In response to Re: brown hot water | |
: The water that is flowing from my hot water lines is brown. After 1 or 2 minutes of flow, the water turns clear, but the problem occurs every time the water is turned on. We have copper pipes. : My thoughts are that the anode rod has corroded completely, but I thought I should seek an expert's opinion. : Tim TIM:TRY DRAINING THE WATER HEATER,,YOU WILL FIND THAT MANY MINERALS |
| There are none. |
