Re: Cast Iron Water Rads
Posted by OLdfangled person on February 05, 19100 at 13:11:11:
In response to Re: Cast Iron Water Rads
: I've seen lots of posts about radiators with no heat - I'm trying my best to isolate my problem.
: I have hot water rads throughout the house. Recently, I removed all the rads in the basement to install some drywall. The rads upstairs are on the same loop and were neer turned off and worked fine. When I hooked the raditars back up they fill with water but when I bleed them, the water is not hot and, of course, the rads don't give off any heat. All valves are open - bled the rads upstairs.
: I've seen comments for tohers sugesting broken values and air locks/pockets. I'm just wondering what my next step would be - what if there is an air lock? How does it come out?
Replies to this post
There are none.
