Re: Fiberglass shower stall install
Posted by Dale's Plumbing Service LMP on February 03, 19100 at 19:51:33:
In response to Re: Fiberglass shower stall install
: Ok so here i am like others, a do it yourselfer.. I bought a shower stall that fit into my house and now I need advice on how to install it..
: I am taking out a fiberglass tub unit that I will sawzall to get out of the house... the bathroom is gutted. the plumbing is easily accessible
: for the supply and drain. I understand the concept of framing around the 3 sides of the stall, BUT the stall lip on the fron is a little longer than
: the height of the back.. so what kind of platform do I build underneath to set the shower on? I can handle most anything with just
: a few tips as a guide to help me get started...
: thanks.
: -chris
Chris. Cut a 5" round hole for the drain hole. Install the drain useing silicone on the flange. This shower should set level on the floor unless it is wider than the tub. Use your skill saw and set it to the depth to cut only the thicknest you need to get to the sub floor and take that piece out. The drain will have to be 2" and it will have to be relocated. Hope this helps. Dale's Plumbing Service LMP
Replies to this post
There are none.
