| Posted by Dale's Plumbing Service LMP on February 03, 19100 at 19:42:16: | |
| In response to Re: Expansion Tank Removal | |
: Are there any special precautions or procedures for removing : the expansion tank that is on the cold water inlet to the : hot water heater? : I need to remove mine so I can TEE into the incoming cold water : Also, what's the proper way for this tank to be attached to the : Thanks in advance for any advice. Andy, shut off the water to the house and open up your outside hydrants and get rid of the pressure. Then put a hose on the water heater drain and let a qt or so out and unscrew the expansion tank. This tank should be screwed into a tee on reinstallation. You may want to put a brass nipple and a 1/2" ball valve before the tank. Easier to work on in the future. Dale's Plumbing Service LMP |
| There are none. |
