Re: pin hole leaks in iron pipe
Posted by Dale's Plumbing Service LMP on February 03, 19100 at 19:31:49:
In response to Re: pin hole leaks in iron pipe
: I have a home with half iron pipe and half copper (due to a remodel before I got it). the iron pipe is in an attic area and has a pin hole leak (I patched it). I've heard that you can re-line pipe. what's involved in that process and is it cheaper than tearing out the old galv pipe and installing new copper? the water is usually very rusty when I first open a valve in the morning. Any information would be greatly appriciated. thank you.
alex, Don'e hesitate a min, Just tear it out. Do plumbers use the pex water piping in your area. It is the going thing now. Dale's Plumbing Service LMP
Replies to this post
There are none.
