| Posted by Dale's Plumbing Service LMP on February 03, 19100 at 19:28:57: | |
| In response to Re: Expansion Tank / Shutting off water to house | |
: Trying to shut off the water to the house to do some plumbing work: : I found that when I shut the water off at the meter, I was still : I noticed that there is a gate valve immediately "upstream" from the Andy, shut off the meter and then open up your outside faucets and the water in the system above the hydrants will drain down. You will have a little pressure from the expansion tank but not that much to worry about. Make sure the city valve is closed all the way. I have run accross bad valves in my time that the city had to change. Dale's Plumbing Service LMP |
| There are none. |
