Are there any special precautions or procedures for removing the expansion tank that is on the cold water inlet to the hot water heater?I need to remove mine so I can TEE into the incoming cold water line (to run a new pipe to the shower), but don't want have hot water spewing all over the place as soon as I loosen it. Is there a way to relieve the pressure in it first, or should I open the breaker for the hot water heater and let it all cool down first? Also, what's the proper way for this tank to be attached to the cold water inlet line? It looks like the guy who put it in just drilled a hole in the steel inlet pipe wall and used a rubber gasket and clamp to attach the expansion tank to the pipe. Is it more appropriate to install a TEE connector and a threaded pipe to the expansion tank? Thanks in advance for any advice.
