| Posted by Dale's Plumbing Service LMP on February 02, 19100 at 19:56:50: | |
| In response to Re: Noises in water pipes | |
: I am in a new double wide trailer (excuse me - manufactured home). Moved in two months ago. : Since day one, there occurs a repeating sort of 'thumping' or 'light banking' noise whenever water is : drawn, HOT Or COLD. The noises come from both ends of the home as well as the middle. The : significance of that would be I guess that I have a bathroom at either end and the kitchen is in the middle. : All have sinks etc of course. The noise continues for a few minutes before stopping completely. : I have a well with submersible pump and a pressure tank under the house in crawl space. : Thanks for any suggestions. I'll try anything, : John John, try shuting off the hot water only. If the noise continues then you have it pegged to cold water only. Or it could be the other way around. You are just going to have to use trial and error on something like this. It could be a bad ballcock in the toilet. A loose washer, a valve that is not opened all the way. Hope this helps.Dale's Plumbing Service LMP |
| There are none. |
