| Posted by Dale's Plumbing Service LMP on February 01, 19100 at 16:35:42: | |
| In response to Re: STALL SHOWER LEAK | |
: i HAVE A STALL SHOWER WITH A WHITE VINYL PAN AND THERE IS A LEAK FROM THE DRAIN TO THE FLOOR BELOW. IS A GASKET SUPPOSE TO BE ON THAT PIPE AND IS POSSIBLY WORN OR DRIED OUT?? John, Yes it it possable that the gasket is worn. Plug off the drain and fill the shower with water. Let it stand over night. If water goes down the gasket is leaking or the caulking is bad on the shower drain. Also you may have a crack in the vinal pan.Dale's Plumbing Service LMP |
| There are none. |
