Before I spend a lot of money in replacing valves/faucets, I thought I'd ask you guys again for help. My diverter in the shower has a continuous leak through the spout while the water is running through the shower head. Will this condition cause the water pressure to the shower to decrease? Will replacing the o-rings/seals in the diverter correct this? You're advice on a previous problem was of immense help. Not only did it correct the problem, but it saved me alot of time and money. THANKS ALOT!!!Since you helped me, maybe I can help you - www.excelir.com/deb
