Re: Shower Drain
Posted by Dale's Plumbing Service LMP on January 31, 19100 at 19:17:40:
In response to Re: Shower Drain
: I am replacing a terrazo shower base on a cement floor with a granite composite. How do I interface with the drain in the cement floor to the drain in the shower base? What is the part called?
: Thank You,
: Ben
Ben, Is this granite similar to the terrazo base? If it is you just need a 2 " shower drain and you may have to move the existing drain to the new opening in the base. You can change the old cast iron to plastic. The pipe will come up into the new drain and have a rubber gasket in it. Dale's Plumbing Service LMP
Replies to this post
There are none.
