| Posted by Mike Jarvis on July 18, 1998 at 09:45:22: | |
| In response to Re: Which one is better? Tub-Showers... | |
Kelli, It is unfortunate that your supplier won't come through for you, however, one thing that should be done, if it hasn't already, is to inject low expansion polyurethane foam underneath the base. Fiberglass tubs do not have the strength required on their own. Hopefully your supplier has a repair technician that knows what they are doing! Good Luck,
| There are none. |
