Re: low water pressure
Posted by Dale's Plumbing Service LMP on January 28, 19100 at 20:59:23:
In response to Re: low water pressure
: The water pressure in my house is very low, especially in the kitchen. We are the first to live there. The tank/pump? pressure is at 35psi. Is that normal, or can it be increased?
Jennifer, Yes you can increase the pressure by increasing the air pressure in your tank and ALSO increase the on off pressure switch. I suggest you call a pump man if you are not formilar with the procedure to do this task.Dale's Plumbing Service LMP
Replies to this post
There are none.
