Re: How do I find the leak??
Posted by Bud...Suncoast Plumbing Inc. on July 17, 1998 at 21:08:52:
In response to Re: How do I find the leak??
J.J.:--There is no magic to finding a leak. It requires a little patience, and sometimes some sophisticated equipment. In your case you should determine if the leak is from the waste piping in the wall or a pressure leak from the water supply to the faucet. It will still require a small hole be made to determine the course of action to be taken. We use a borescope, which is like a medical instrument, it is inserted into the suspected area through a 1/4" hole ,and is able to take a color video of the problem. The repair will require the opening of a wall or ceiling to gain access to the site needing a little TLC. Sorry....you can't remove an appendix without making a little hole either....Lots of luck...Bud
Replies to this post
There are none. |
