| Posted by hj on January 28, 19100 at 08:53:38: | |
| In response to Re: sodium content in water when using a salt based water softener | |
It definitely increases since the ion exchange process replaces calcium ions with the sodium ions from the salt. It is for this reasons that persons on low sodium diets either use Pottassium or get reverse osmosis water conditioners for drinking water purposes. : If you use a salt based water softener does the sodium content of the water increase? If so by how much? how can you test for the sodium content in the water?
| There are none. |
