| Posted by hj on January 27, 19100 at 01:17:34: | |
| In response to Re: How much teflon tape to use? | |
When a study was conducted on PVC joints that failed, it was found that it was because too much tape had been used and it cracked the fittings. Obviously that will not happen with metal pipe and fittings, but, normally no more than two layers are needed. However the important thing to remember is that the tape, or any other thread compound's, prime purpose is to reduce friction, so that the mating threads will make full contact. Filling any voids is a secondary function, so if the threads are old and rusty, there may be nothing that will prevent them from leaking. : : Thanks in advance for any advice.
