| Posted by hj on January 25, 19100 at 00:06:10: | |
| In response to Re: MEON single stem shower valve | |
You need to contact a good plumber. I have 4 different tools to extract the cartridges and usually the correct one for a particular situation can remove it in about 30 seconds. : I purchased OEM MOEN valve replacement cartridge and valve removal & replacement tool. After removing the retaining clip , I used tool to attempt to remove 26yr old cartridge. The old ears on old valve insert were coroded thin so, that it futile to attempt to turn valve. The valve also could not be pulled using the puller. HELP. I have soaked the coroded opening with CLR for 2 mo. and old valve still cannot be extracted. What can I do to get this old incert out!!!!!
| There are none. |
