MEON single stem shower valve
Posted by GRANT PHILLIPS on January 24, 19100 at 15:42:32:
I purchased OEM MOEN valve replacement cartridge and valve removal & replacement tool. After removing the retaining clip , I used tool to attempt to remove 26yr old cartridge. The old ears on old valve insert were coroded thin so, that it futile to attempt to turn valve. The valve also could not be pulled using the puller. HELP. I have soaked the coroded opening with CLR for 2 mo. and old valve still cannot be extracted. What can I do to get this old incert out!!!!!
