| Posted by Tom Doster on January 24, 19100 at 14:36:08: | |
I want to reposition the ball valves feeding my washing machine and would like to know of any concerns about reusing pieces. The pipes in the wall run vertical and are half-inch copper. I want to disconnect the valve at the T and replace it with Will the T be clean enough to reuse once I remove the existing Will I have to clean the inside of the T-leg? With what and how I assume that everything after that is as normal: flux, fit Related question: What can I use from around the house to |
| There are none. |
