| Posted by Dale's Plumbing Service LMP on January 24, 19100 at 03:52:04: | |
| In response to Re: sewer problem | |
: There is standing water in my sewer line from the outside clean-out to where the sewer line meets : the city "stub-in". I discovered this after basement flooded a 3rd time in 5 years. I finally had the : sewer line cameraed. Unfortunately, it is unclear as the whether or not there was ever enough grade : to begin with. I don't know if there is an "elebow" because of settling or because there was an : "oops" when the pipe was connected to the city stub. Rodding out the sewer seems to work however : I am trying to sell my house and a potential buyer is not to sure about buying into the problem... : especially not knowing if there is enough grade. My question to you is, is a sewer ejector a better : solution? Would I put it next to the outside clean out since that is where the problem is? Would I : put it in the basement? There is no bathroom in the basement, would this 'sewer problem' prevent a : toilet from working 'normally'? Is there any way I could get restitution from either the Contractor : or the Plumbing contractor? I would appreciate any help or advice that you can give me. Thanks. : Sincerely, Judy, If you had this line camered it should tell you what the problem is with this line.A sewer lift station isn't the answer to the problem unless you run the line to the sewer tap.I doubt if your local plumbing code will let you do it. Dale's Plumbing Service LMP |
| There are none. |
